Old 9-Oct-2012, 8:26 AM   #8
The CM4228HD does better at receiving at the low end of the UHF.
Channels 14 thru 30 where you require it the most , that is why I recommend the CM4228HD for your reception.
http://www.antennahacks.com/Comparis...228_vs_DB8.htm.
http://www.antennahacks.com/Comparis..._vs_HD8800.htm.
And the CPA-19 preamp is a low noise mid gain preamp that will tolerate high signal strengths with out over load , and works with other antennas , that is why I recommended it.
____________________________
Getting closer to the Truth helps in the middle of the day.
