Old 11-Oct-2010, 11:00 PM   #3
mtownsend
Hello and welcome!
It looks like there are three groups of transmitters for you to consider...
1) KOAC (PBS, channel 7 / 7.1) and K14GW-D (Fox / MyN, channel 14 / 34.1) broadcast from Corvallis around compass heading 263º. These are two of the closest and strongest transmitters in your area. These stations are going to duplicate much of the programming you'd get from the stations KEPB and KLSR broadcasting out of Eugene.
2) Most of your "local" stations are broadcasting from Eugene around compass heading 170º, roughly 40 miles away. These signals are reasonably strong, so you should have no problem getting them with a rooftop antenna.
3) Several of the Portland stations are also available to the north (compass heading 356º, about 64 miles away). These signals are weaker due to some terrain blockage and the greater distance, but they are still within reach if you use a high gain antenna.
I would suggest two possible setups, depending on what's important to you:
I) If you are content with just the Eugene stations, then you can use an antenna like the Winegard HD7694P or Antennacraft HBU-33 pointed south. Since you should be able to pick up KEPB and KLSR with this setup, there is probably no need to worry about the two transmitters in Corvallis.
II) If you want to get the Portland stations as well, then you will need to have an antenna rotator (like the Channel Master 9521A) or an A/B switch to deal with stations coming from multiple directions. The weaker Portland stations will require a larger antenna like the Winegard HD7697P or Antennacraft HBU-55. If you use an antenna rotator with this kind of antenna, you should be able to pick up most of the stations down into the "red" zone on your TV Fool report by turning your antenna to the appropriate direction. You should be able to get Portland, Corvallis, or Eugene stations this way, but you cannot get them all at the same time (because the antenna can only point to one group at a time).
If you plan on splitting the signal to multiple rooms, or if the length of coax is going to be long (more than say 50 feet), then I would suggest also adding a mast-mounted pre-amp like the Channel Master 7777, Winegard AP-8700, or Antennacraft 10G202.
