There's not a great deal of difference between the first and second TVFR, but thanks.
The high gain & wide beam-width of the DB4e makes it my choice for going after the signals to the NW and SW. Try this with no amplifier. If you try an amplifier, it needs to be able to handle fairly strong signals. The Channel Master CM341x series distribution amplifiers fit that criteria.
Try it in the attic, but if it fails to do well there, at least 'test' it outside. I think you'll be able to see a marked improvement in signal quality if you mount outside.
