Old 9-Oct-2012, 3:33 AM   #15
Originally Posted by fstr View Post
I go from perfect signal to crap - and it lasts for minutes or hours. I am surrounded by tall trees, but then you would expect less problems in the winter and not the type of interference I'm having. I have investigated all the stuff in my house (short of tripping breakers though). Just not sure how I can investigate the rest of the stuff in the neighborhood.
One TV failing could back feed interference into the others. Isolating one TV to a test antenna with no amplifier would be my next step. If all TVs fail the same in this configuration, it suggests interference via an over the air path. If only the test TV fails, you're closing in on the culprit. If all but the test TV fail, you're still making logical progress, one of the TVs or a common part in the cabling is suspect.
