Hi antenna Gurus,
Well, it's been a while...and sorry to say shortly after my prior posts I became very ill and spent much time in the hospital.
As mentioned prior, Cable/Comcast was canceled, I did purchase the Winegard 7000R, Ronard chimney mount, but was not able to get up on the roof.
I've been dealing with a little $9 RCA-ANT111 however, I'm now healthy enough to install my rooftop antenna.
The only item I require is some 40' of coax to run from the antenna, down the back of the house and I'll then connect to the existing coaxial cable in my home.
Question...when ordering outdoor coaxial cable, is there anything 'special' I need to look for, especially for signal?
Again, I can't thank you enough for your advice.
Kindest Regards, Ray
