Old 9-Oct-2012, 2:35 AM   #5
tdew2
Originally Posted by teleview View Post
Please note that the tvfool radar plot report is resolved to street level only.
Based on the street level report.
The following recommendation will receive the Digital Tv stations/channels in the Green and Yellow reception zones of the tvfool radar reports channels list and that is - a lot - of channels.
For reception of the most number of Digital Tv stations/channels , to the , north west , west , south east , and that is - a lot - of digital Tv stations/channels.
Above the roof , install a Antennas Direct Clear Stream 4 UHF antenna aimed at about 280 degree magnetic compass direction with the reflector screens removed and the CS4 will receive Digital Tv stations/channels to the , north west , west , south east. At the front and back of the CS4 because the reflector screens are removed.
Also install a Antenna Craft CS600 VHF antenna aimed at about 335 degree magnetic compass direction for reception of the Digital VHF stations/channels to the , north west and south east.
I am researching reception information I will return.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
I'm guessing my address isn't in their database, however I'm assuming street level is fine. I live on a small street in a small town.
I live in a development where the hoa doesn't approve of roof mounted antennas. Think I'm out of luck?
Antenna's direct emailed me today with the below recommendation:
I'd suggest a DB4e with option VHF add-on (see attachment) plus a rotor. Because of the spreads and distances involved, it's unlikely you'll readily find a single aiming direction that will outperform an antenna that is accurately aimed. Here is the VHF add on: http://www.antennasdirect.com/store/...-Assembly.html
Again though, I'd like to avoid having to use a rotor. I could see having a VHF/UHF combo (I assume I would use a combiner).
Is there an antenna that I could point between the Greensboro (Southwest) market (245) and 285 to pick up all the major networks, reliably?
Also, what stations would be VHF? I think I may be reading the report incorrectly, but thought that VHF would be 2-13 "real" channel?
Thank you again!!!
tdew2 is offline   Reply With Quote
