Old 9-Oct-2012, 1:49 AM   #4
tdew2
If you don't get reliable reception in the attic, are you willing to mount outdoors?
How many traditional TVs will be connected?
What model HDHR do you have? (The newer HDHR3-US with single antenna connector or the older dual input HDHR-US?)
Have you read http://forum.tvfool.com/showthread.php?t=820?
I will actually connect one traditional TV, and two HDHR's. I have two different HDHR models - one older, one newer (links below).
http://www.amazon.com/SiliconDust-HD...ords=hdhomerun
I'd really prefer to stick to one antenna, if possible. I checked the other thread regarding HDHR, sounds like he has multiple antennas, but has to switch between HDHR's depending on which channels he's watching. I live in a development in which the hoa won't allow antennas to be posted on the roof.
Is there one antenna that could be aimed to the southeast between 240-285 degrees and pick up all the major networks and PBS? I'd be willing to give up the other markets, as long as I could get those networks.
Thank you for the advice!!!
tdew2 is offline   Reply With Quote
