Old 8-Oct-2012, 10:44 PM   #5
fstr
Do you have a 'spare' antenna lying around? The DB4 perhaps?
If so, can you set up one tuner (TV or HDHR) fed by the 'test' antenna, barefoot (no amplifier)?
Any aircraft in the area? A freeway or road with occasional large truck traffic?
Im not close to a freeway or large trucks, nor airport but have the regular overhead jumbo jets high up
It's normally difficult to work on the issue because it needs to pop up - but it just so happens that now it is happening. (lucky me)
So I routed the coax from the antenna just to one tuner. So I have a solid 25ft coax running directly from the antenna to 1 tuner - nothing else in between and I get exactly the same signal asmy "regular" setup
fstr is offline   Reply With Quote
