A few thoughts to consider:
1) If you're going to use an omni antenna like the CM 3000A, it should be installed outdoors, preferably on the roof. When you install antennas like this inside a building, it may suffer from multipath issues (too many signals bouncing around surrounding objects).
2) Due to the strong signal strengths in your area, I'd suggest a Winegard MS-1000 as a better option than the Channel Master 3000A because the built-in amp on the 3000A might get overloaded by too much signal. Again, if going with an omni antenna, please install it on the roof out in the open.
3) Omni antennas are never quite perfectly "omni" in all directions. They still receive a little better in some directions than in others. That is the only reason it is sometimes said that you need to "aim" the omni antenna a bit. This is just something you need to do once during initial antenna installation. Just experiment with the antenna rotated slightly in different directions to see which position gives you the best overall reception across all channels. Once it has been "aimed", you don't need to bother with it again. The installation of omni antennas is no more difficult than installing a directional antenna.
4) The CM 3016 is a directional antenna. Most of your channels are coming from the large group of Philadelphia transmitters at compass heading 286ยบ. If you do not install an antenna rotator, you might not be able to pick up some of the weaker stations coming from other directions (like WFMZ). You might get lucky with some of the really strong channels sneaking in through the "back" of the antenna, but there's no guarantee that they will be as stable as the Philly channels. You still have plenty of channels even if you only get the Philly stations, so maybe these extra channels are not all that important to you.
5) WNJS (PBS, channel 22 / 23.1) is the strongest non-Philly station on your list, with a Noise Margin of about 59 dB. If you install the 3016 antenna on the roof, there is pretty good chance that you can pick up WNJS through the "back" of the antenna.
