Old 8-Oct-2012, 6:12 PM   #2
The following recommendation will receive the Digital Tv stations/channels in the Green and Yellow reception zones of the tvfool radar reports channels list and that is - a lot - of channels.
For reception of the most number of Digital Tv stations/channels , to the , north west , west , south east , and that is - a lot - of digital Tv stations/channels.
Above the Roof , install a Antennas Direct Clear Stream 4 UHF antenna aimed at about 280 degree magnetic compass direction with the -> reflector screens removed <- and the CS4 will receive Digital Tv stations/channels to the , north west , west , south east. At the front and back of the CS4 because the reflector screens are removed.
Above the Roof , Also install a Antenna Craft CS600 VHF antenna aimed at about 335 degree magnetic compass direction for reception of the Digital VHF stations/channels to the , north west and south east.
Combine the the CS4 and CS600 antennas with a Pico Macom , UVSJ = UHF/VHF Separator/Joiner.
Connect CS4 to the UHF connection , connect the CS600 to the VHF connection and the third connection is a single coax down lead.
The UVSJ , passes power through the third connection and the VHF connection , Install a Antennas Direct CPA-19 preamp unit in between the CS600 antenna and the VHF connection of the UVSJ.
The power injector and power supply of the CPA-19 preamp can be in the house because the UVSJ passes power through the third connection and VHF connection of the UVSJ. The preamp unit that is in between the CS600 and VHF connection of the UVSJ will amplify the weaker VHF channels.
Buy the UVSJ at solidsignal by typing the letters uvsj in the solidsignal search box.
For 1 Tv connection use no splitter.
For 2 connections use a , HFS-2D , 2 way splitter.
For 3 connections use a , HFS-3D , 3 way splitter.
For 4 connections use a , HFS-4D , 4 way splitter.
Buy the HFS splitter at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
____________
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.antennacraft.net.
It is best to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's / tuning devices must channel scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
