With the DB4e aimed to east , and PBS is on channel 13 to the east and PBS is on channel 25 to the west , but the reflector screen is on the DB4e blocking reception to the west and a UVSJ is connected , does that mean that the DB4e's reflector screen will need to be removed to receive PBS channel 25 to the west?? And if so , will the gain of the DB4e with out a reflector screen be greater then the CS4 with out a reflector screen.
KXJB UHF 38 and KVLY 44 are strong signals , well at least compared to the other UHF signals.
And WDAY UHF 21 is the same as WDAZ VHF 8 that will most likely be received through the back of the YA1713 antenna.
And the UHF channels are being received now with the omnidirectional antenna and most likely it is not doing as good of job of receiving the UHF channels as the CS4 and DB4e will do with their reflector screens removed.
