Old 7-Oct-2012, 5:22 PM   #11
1. As has been stated , the antenna is aimed at about 33 degree magnetic compass direction because of the weak signal strength WENH PBS Tv station.
The ANT751 is a directional antenna and as such receives the best in the forward direction , However the ANT751 is Not a very directional antenna so the the ANT751 will receive the stronger Tv stations of other directions.
The other Tv stations other directions in the green and yellow reception zones are much stronger signal strength
2. How many Tv's are/will be connected??
3. I see a tree in the left hand side of the picture that is close to the house.
As has been stated , It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Do not install the antenna on the end of the house that is close to the tree if that tree is in one of the directions of reception that is shown in the left hand side of the picture.
You may recall this statement , As always trees and tree leaves do a real fine job of reducing or blocking reception and so do buildings and other obstructions.
What direction is tree in the left hand side of the picture??
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html ,http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box. http://www.solidsignal.com.
