Old 7-Oct-2012, 10:49 AM   #2
Install a CM4228HD for the UHF channels aimed at about 285 degree magnetic compass direction.
Install a Antennas Direct C5 for the VHF channels , WBQP-CD channel 12 America One , WALA-DT channel 9 FOX , aimed at about 285 degree magnetic compass direction.
The C5 comes with a combiner to combine the CM4228HD and C5 on to one coax.
The CM4228HD is connected to the UHF connection of the combiner and the C5 is connected to VHF connection of the combiner and the 3rd connection of the combiner will have a Antennas Direct CPA-19 preamp connected.
For one Tv location use no splitter.
For 2 Tv locations use a , HFS-2D , 2 way splitter.
For 3 Tv locations use a , HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some places to by antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
Here is a tripod antenna mount for above the roof of your house , might get the antennas high enough , the 10 tripod and the mast even higher then the tripod. , the tripod mount uses no guy wires.
http://www.ronard.com/Tripods%200703/4712.html. Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box.
