I am doing more research. And more research.
Buy reverse engineering to close to your location. I see that the YA1713 antenna does not need to be at 65 feet antenna height for reception.
A antenna height of , 20 , 30 , 40 , feet above ground gives signal strengths of +18 or so NM (dB).
The NM(dB) at 65 feet is +17 NM(dB).
So that means that the YA1713 antenna does not have to be 65 feet above ground. 20 or 30 feet will be fine for reception.
Installing a antenna at 20 feet above ground is easier on the nerves then 65 feet.
And with a better antenna for the other Tv stations channels then the omnidirectional antenna , it looks like the better antenna will not be required to be 65 feet in the air for all the other channels.
Please post 2 more tvfool radar plot reports , 20 feet and 40 feet.
