The ANT751 is a small well made antenna that will stand up to the elements.
The , CM4221HD , Winegard 4400 , Antennas Direct DB4 , are all real fine ->DIRECTIONAL <- antennas that receive almost no signal at the sides and less then the front because of the reflectors behind the reception elements.
And the antennas are designed to receive the UHF channels 14 thru 51 the best.
Your location has Tv stations to receive in the UHF band channels 14 thru 51 and VHF high band channels 7 thru 13.
That is why I am recommending a ANT751 that is designed to receive UHF channels 14 thru 51 and VHF channels 7 thru 13.
The ANT751 is not a very directional antenna and as such will receive the Tv stations to , north west , north east , south west , south east.
