Old 6-Oct-2012, 4:23 PM   #6
Tv antenna rotators Are Not Channel Surfing Friendly , must wait for antenna to rotate , And , not every one in the house will agree with the direction a more directional antenna is aimed.
___________________________________
The other Tv stations/channels to receive are Much Weaker of signal strength.
W40BO . W40BO is the same as WBPX ION , WBPX ION is received with the ANT751.
WNAC-DT FOX. However WFXT-DT - FOX is received with the ANT751 antenna.
WPRI-TV CBS. However WBZ - CBS is received with the ANT751 antenna.
WJAR NBC . However WHDH - NBC is received with the ANT751 antenna.
WLNE-DT ABC. However WMUR - ABC and WCVB - ABC are received with the ANT751 antenna.
However if you will like to receive , WNAC , WPRI , WJAR , WLNE , to the south then I recommend a Larger antenna , a Winegard HD7698P antenna , Dedicated , to receiving those Weak Tv stations to the south.
For 1 Tv connection use no splitter , use no antenna amplifier.
For 2 Tv's connected use a CM3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
The HD7698P antenna is a SEPARATE antenna system and Is Not connected to ANT751.
The ANT751 antenna system and the HD7698P antenna system are 2 SEPARATE antenna systems that are Not connected together on to one coax.
The 2 Separate antenna systems are connected to a remote control A/B antenna switch at each Tv location. http://www.radioshack.com , #15-1968. , or , http://www.mcmelectronics.com , #32-4425 .
Remote control A/B antenna coax switching Is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
