Old 6-Oct-2012, 10:22 AM   #9
ILoveCoffee
There is a window on the east side. I kept the antenna in the window and received only 5 channels.
Next was on the TV set, next to the window, lying flat, received 17 channels (31.xxx never really received)
Now standing on the TV, next to the window facing south-west, received 25 channels, no new channels really identified, only few sub-channels (which were essentially the same like 9.1 and 9.2. Again, 31.xxx never really received.
Terk FDTV1a is an omni-directional antenna. Their manual suggests to keep it away from metallic objects. Most likely, that is the reason, why it recognized only 5 channels in the window and little more as it stood on top of the TV next to the window.
If you need, I will post the picture of the set up.
ILoveCoffee is offline   Reply With Quote
