Old 11-Oct-2010, 3:37 PM   #6
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
It's permissible to mount the preamp in between the two antennas, if you like, just be sure that the antennas are a minimum of 4' apart vertically on the same mast. I also recommend tilting the XG-91 UP in the front about 15 degrees to help overcome the refraction effects of the hills.
