Old 6-Oct-2012, 2:46 AM   #5
Both antennas are relatively compact, with a small wind load. A securely installed J-pole should be stressed less when carrying one of these antennas than a satellite dish. One thing to watch out for though, avoid pointing the antenna into the roof. Satellite installs are often on the south side of the building so there's a clear view of the satellite which is south of everyone in the northern hemisphere. You need to aim NW for reception of the TV signals so you might have a roof or other part of the building in the way.
