Hi Teleview,
The converter box (Zinwell) and antenna (Terk FDTV1a) arrived today. I played with it for about 2 hours to see which direction/position gives me best channels. Finally, I guess I found the location and position where I will get maximum number of channels. I don't get all of them though. The ones I get are listed below. It will be great if you could go through and check why I am not getting others, if you could figure out the problem i.e. their wavelength or direction or anything else.
2.1 WCBS-HD
2.2 CBSNY+
4.1 WNBC
4.2 NonStop
5.1 WNYW
9.1 WWOR-TV
31.1 ION
31.2 qubo
31.3 ION life
31.100 Airbox
31.101 Starz
31.200 NFL
31.201 Redzone
31.209 GolTV
31.300 Telefor
31.301 CInemax
31.302 Pasions
41.1 WXTV-DT
41.2 WFUT-DT
Out of these only 2 to 9 are received reliably. 31.x reception is little finicky and 31.xxx reception is zero. It shows good signal and signal strenth but no picture or audio. No idea what is going on. I have no idea why I do not get first 3 channels in TVfool radar report. Any pointers are appreciated.
Thanks in advance.
