Old 5-Oct-2012, 10:07 PM   #3
Many Tv stations/channels will be received.
Install a ANT751 antenna with no antenna amplifier above the roof aimed at about 310 degree magnetic compass direction.
http://www.solidsignal.com , has a ANT751 antenna with a J type antenna mount , low dollars.
For 1 Tv connection use no splitter.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
It is best install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
_____________________________________
Antenna web and Antenna point , are defective web sites that are misleading many people with bad information. The web sites are defective now for a Long Time , the owners know that they are defective , and do not fix them and do not take them down.
A very sad and defective situation for those that are being mislead with bad information.
