Old 5-Oct-2012, 8:47 PM   #4
Quote , "My TV is an older Sony 52" LCD".
That is why I suggested the newer Palsma Tv.
And yes can do the double rescan on both Tv's.
Also the phasing lines are in the matching transformer housing , make sure they are in there correctly and the connections of the matching transformer part of in the housing are making connections with the phasing lines.
Antenna aiming is not supper critical as to getting antenna right on the money as to degrees magnetic compass direction.
As always , the starting aim direction is the -> starting aim direction.
Then the antenna can be turned left and right to find a position that has the best reception.
Do not get your self all twisted up and tangled up with this idea and that idea and some other idea and lose track of what it is you are doing.
What you are doing is , Aim the HD8200U antenna at about 246 degrees magnetic compass direction.
Connect a NEW long coax to the HD8200U antenna and run the NEW long coax through a open door or window direct to the Tv location , do not connect the New long coax to the Tv , remove any and all coaxes that are connected to the Tv and the antenna connection of the Tv.
Scan for Digital Broadcast Tv Channels to clear out the tuner , No antenna connected.
Connect the New long antenna connected coax to the antenna input connection of the the Tv and scan for Digital Broadcast Tv Channels.
What is reception of WNYW FOX like now??
_____________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Quote , "My antenna is about 20-30 feet up on the side of my house".
The antenna Must Be mounted in such a manner the house Is Not obstructing the reception of Tv transmissions to the , north west , west , south , south east , east , north east.
