Old 5-Oct-2012, 6:42 PM   #2
Your TV Fool Report shows a very favorable outlook, with no obstructions between you and the transmitters, most of which are apparently on much higher terrain. Your report indicates 'Line of Sight' for most signals.
If the posted report is accurate, a small antenna such as the RCA ANT-751 or Antennacraft HBU-22 is plenty. You have enough signal power to drive several TVs.
Point the antenna toward 310° to start, adjust in small steps, left and right to be sure you have the best aim point.
