Old 5-Oct-2012, 5:31 PM   #2
Disconnect and remove the , preamp , the preamp power supply , the preamp power injector.
Disconnect and remove the MS2000.
Make sure the phasing lines of the HD8200U are connected correctly and not touching the boom as shown at http://www.winegarddirect.com.
Aim the HD8200U antenna at about 246 degree magnetic compass direction , WNYW UHF channel 44 FOX.
Connect a New long coax directly to HD8200U antenna and run the coax through a open window or door , directly to the New Plasma Tv.
Before connecting the One Long Coax that comes from the HD8200U antenna , remove any coax that is connected to the antenna connection on the Tv.
Digital Channels can develop , Digital Glitches.
Simply re scanning will often times not remove the Digital Glitches.
With No coax connected the Tv , You will do what is called a Double Rescan.
With No antenna connected to the Tv , Scan for Digital Broadcast Tv Channels , do not scan for cable Tv channels.
With No antenna connected to the Tv this , Clears Out , the tuner for a fresh scan for channels.
Now connect the antenna coax to the Tv and scan for channels.
Is WNYW Fox received now??
