Teleview,
I took your advice and finally got the Clearstream 2 complete antenna and I'm going to install it this weekend. From what I am reading, you suggest removing the reflector and just use the CS2 complete only (the loop element bow tie part)....Is that correct ? If so, should I use the reflector for Any thing at all?
Should I use the collapsable dipole adjustable arms that are attached to the reflector?
