Old 4-Oct-2012, 3:44 AM   #3
The groups of Tv stations are to the , east , south east , south.
For best reception , aim the DB2 antenna at about 125 degree magnetic compass direction.
Put the antenna in a window or out on a patio/balcony that is to the south east as a first choice.
Can also put the DB2 antenna a window or out on a patio/balcony that is toward the south or east.
If the DB2 antenna is out on a patio/balcony , a way to get the coax from patio/balcony to inside the apartment is through a hole through the wall.
Here is an other way , Flat Coax , Eagle Aspen , FC-300LX , http://www.solidsignal.com.
It is best to locate the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channel' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
