Old 3-Oct-2012, 10:01 AM   #3
Aim the HBU33 antenna at about 340 degree magnetic compass direction.
Install a Antennas Direct CPA-19 preamp with the HBU33 antenna.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are places to buy the CPA-19 preamp. http://www.solidsignal.com , http://www.amazon.com.
It is best to install the antenna at a location that has least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channel' or 'Antenna Channels' in Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
