Old 2-Oct-2012, 6:53 AM   #8
A Simple reception situation.
For reception of ,
KHNE-DT REAL UHF channel 28 , virtual number (29.1-2-3) PBS.
K56FC REAL UHF channel 50 , virtual number (50.1) Licensed and Silent.
KHAS-DT REAL VHF channel 05 , virtual number (5.1-2) NBC and This Tv.
KGIN-DT REAL VHF channel 11 , virtual number (11.1-2) CBS and MyNetwork.
KHGI-TV REAL VHF channel 13 , virtual number (13.1-2) ABC and FOX.
Above the Roof install a Winegard HD7082P antenna with - no preamp - aimed at about 192 degree magnetic compass direction.
For 1 Tv connected use no splitter , no antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no antenna amplifier.
For 3 Tv's connected use a common simple 3 way splitter , no antenna amplifier.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Herte are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
For your location that is , south west , south , south east.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
