Thread: bad area
Old 2-Oct-2012, 12:41 AM   #2
Above The Roof , install a Winegard HD7084P antenna with a Winegard AP8700 preamp aimed at about 114 degree magnetic compass direction.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
This is a Big antenna , do not try and use the small satellite dish mount for the antenna.
Some common roof top antenna mounts are , Tripod antenna mount , Eave antenna mount , Chimney antenna mount.
Here are places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
It is best to install the antenna at a location that has the least amount to no amount of any type or kind of obstructions in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
________________________________________
Here is list of Tv stations/channels. Based on the tvfool Pending Applications Included channel list.
CHRO-Tv , Analog VHF channel 05 , CTV TWO. http://en.wikipedia.org/wiki/CHRO-TV.
CBOFT-D , Digital UHF channel 33 , French Tv.
CIVO-DT , Digital UHF channel 30 , TQ. Tele-Quebec. http://en.wikipedia.org/wiki/CIVO-DT.
CJOH-DT , Digital VHF channel 13 , CTV ONE. http://en.wikipedia.org/wiki/CJOH-DT.
CHOT-DT , Digital UHF channel 40 , TVA. http://en.wikipedia.org/wiki/CHOT-DT
CBOFT-D , Digital UHF channel 09 , French Tv. http://en.wikipedia.org/wiki/CBOFT-DT.
CIII-DT , Digital UHF channel 14 , GTN. http://en.wikipedia.org/wiki/CIII-DT.
CBOT-DT , DIGITAL UHF channel 25 , CBC. http://en.wikipedia.org/wiki/CBOT-DT.
CFGS-DT , Digital UHF channel 34 , V French. http://en.wikipedia.org/wiki/CFGS-DT.
CICO-DT , Digital UHF channel 24 , TVO. http://www.wikipedia.org/wiki/TVOntario.
As always , the Tv antenna can be adjusted for best reception , turn the antenna to the left and right , move the antenna up and down , and can also change location of antenna to find a location for best reception.
