Old 1-Oct-2012, 10:18 PM   #1
kboy
help identifying these antennas
hi. i'm new to this forum and am an absolute novice when it comes all things over the air...hope someone can help.
i recently bought a house in country and it has these two antenna (pls see attached image), there is ribbon wire running to one, not the other. can anyone help me identify what type of antenna these are? i just want to make sure i can pick up over the air tv with them. i also want to get them set up correctly. i think i should replace the 70s ribbon wire with coax which i can re-route to the basement and then run up the wall to a couple of rooms where i will want a tv.
do i need to hook the coax up to both antennas? what is the best way to do this? is one antenna uhf and the other vhf? thanks in advance!
kboy is offline   Reply With Quote
