Old 30-Sep-2012, 9:43 PM   #8
If not interested in the Kansas Repeater Tv stations then aim the Clear Stream 4 at about 332 degree magnetic compass direction.
If will like to use a Separate antenna to receive the Kansas repeater Tv stations then use the travel trailer antenna or install a second Clear Stream 4 antenna aimed at about 87 degree magnetic compass direction. I do not think a antenna amplifier will be required with the second Clear Stream 4 aimed at the Kansas repeaters but if required use a CPA-19 preamp.
The 2 antenna systems are Separate antenna systems and are not connected together on to one coax.
The 2 separate antenna systems are separate all the way to the location/s of the Tv/s and be connected to a Remote control A/B antenna switch at each Tv location. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
___________________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings or other obstructions.
It is best to install the antenna/s at a location that has the least amount to no amount of obstructions in the directions of reception.
