Old 30-Sep-2012, 6:31 PM   #8
Aim one antenna at about 315 degree magnetic compass direction and the oher antenna at about 185 degree magnetic compass direction.
The antennas Must Not be connected together on to one coax.
For 2 SEPARATE antenna systems use a Remote control A/B antenna switch , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
A Remote control A/B antenna switch at each Tv location means that each antenna has it's own Separate coax system going to each Tv.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
It looks like the bottom antenna has a amplifier under it , if it is a amplifier what is the make and model number??
If it is not a amplifier then what is it??
Last edited by GroundUrMast; 30-Sep-2012 at 6:41 PM. Reason: Deleting 'boiler plate' spam style content
