Old 29-Sep-2012, 3:07 PM   #1
Shvingy
Kitchener Ontario CN Tower Signal Assistance
I have a roof mounted DB8 with CM 7778, unobstructed view, about 80 feet of cable, grounded and run through noise filter system. I use an Nfusion HD, for my tuner (There is no other model number on it, the manual or the box other than Nfusion HD). My LCD TV does not have a built in tuner. The antenna is aimed dead straight at 74 degrees.
Still I have troubles obtaining and stabilizing the signal from 74 degrees. Namely CBC (CBLT-DT). Ok here is where it gets messed up, I receive from 74 degrees, ciii-dt (41.1),cblft (which I think is in analogue), city-dt (57.1), cfmt-dt(47.1) but not cfto-dt (9.1), cica-dt(19.1) and cblt-dt (5.1). I am happy with the rest of my system but CBC is kinda the one I need the most. I have also tried the Kross 4 bay whisker antenna. The DB8 holds signals much better.
What angle should my antenna sit up vertically, will this make a difference or is 90 degrees ok?
I was thinking of trying a CM 4228 HD antenna. Will that be any better?
Update: I put up a Kross GY-TVA 003 4 bay whisker antenna up and this offered an improvement on all counts.
http://www.tvfool.com/?option=com_wr...2df9ed9116f1bf
Any help is appreciated.
Shvingy is offline   Reply With Quote
