Old 28-Sep-2012, 5:06 PM   #3
838joel
Hi Teleview!
The way you look at it, yes indeed it is a simple reception situation!
I find it on amazon.ca -> http://www.amazon.ca/Antennas-Direct...8842050&sr=8-1 But is it the same? It looks a little different on pictures!
Anyway, I thought it was a better price, but it is for the antenna only, nothing else! So I think the best place to get it is from antennasdirect.com
You said to remove the reflector screen... not sure of what you are talking about.. the square metal mesh on the back?
To aim about 165 degree I just have to use a magnetic compass? And does the precision is important? Do I need to use a power level meter to get the most of it?
I'm going to use 2 TV, and will probably use the actual splitter I have.
My roof looks like this http://www.dreamstime.com/royalty-fr...k-image6418007, with a brick wall on the side, so I'm thinking using something like this http://www.amazon.com/Winegard-SW-00...na+gable+mount fixed on the brick and having a mast of 5-10 feet high. What do you think, is there better way?
Another thing, I found that there is also a C4 version of this antenna... Should this be a better reception? Or I will gain nothing more then using a C2 version.
Thanks,
Joel
Note: I may check if there is installers available around Montreal, because it may be hard to do it myself... If someone can refer me a good installer it will be appreciated.
838joel is offline   Reply With Quote
