Old 28-Sep-2012, 5:55 AM   #6
Aim the HD5030 at about 270 degree magnetic compass direction for reception of K06PG-D Digital channel 6 , PBS. And KLAS CBS and ME-Tv. And ABC.
Aim the XG91 at about 270 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
Connect the 2 antennas together with a UVSJ = UHF/VHF Separator/Joiner.
Buy the UVSJ buy typing the letters , uvsj , in the http://www.solidsignal.com , search box.
The Tv Must Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
It is best to locate the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
