Old 28-Sep-2012, 2:00 AM   #2
The signal strengths change very little , 10 , 20 , 30 , 40 , feet.
Roof top antenna height will be Ok , 10 , 20 , feet or so will be Ok. If nothing is blocking the signal.
Install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 286 degree magnetic compass direction.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegardirect.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu becauce the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
