Old 28-Sep-2012, 1:27 AM   #2
A Simple reception situation.
Remove the reflector screen from a , Antennas Direct , Clear Stream 2 Complete VHF/UHF antenna , http://www.antennasdirect.com/store/...VHF-Combo.html , and the CS2 Complete will receive Digital Tv stations/channels at the front and back of the antenna.
Aim either side of the CS2 Complete antenna at about 165 degree magnetic compass direction and the CS2 Complete antenna will receive the digital Tv stations/channels to the , north east , east , south east , south west , north west.
For 1 Tv connected use no splitter , no antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no antenna amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Canada and USA Tv stations will be received in the tvfool channel list down to and including WVNY-DT 13 ABC.
Common roof top antenna mounts are , tripod mount , eave mount , chimney mount.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.antennasdirect.com , http://www.channelmasterstore.com.
Do not channel scan for cable tv channels.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
