Old 27-Sep-2012, 6:04 AM   #7
Name141
Originally Posted by teleview View Post
The following is the South group of Tv stations.
The South group of Digital Tv stations/channels are Weak to Very Weak of signal strength.
KLTV-DT REAL VHF channel 07 , virtual number (7.1-2-3) ABC and Bounce and Telemundo.
KFXK-DT REAL UHF channel 31 , virtual number (51.1-2) Fox and MyNetwork.
KCEB REAL UHF channel 51 , virtual number (54.1-2) Me-TV and Mundo fox.
KYTX-DT REAL UHF channel 18 , virtual number (19.1-2-3) CBS and CW and This Tv.
KETK-TV REAL UHF channel 22 , virtual number (56.1-2) NBC and Estrella Tv.
_________________________________________________________________
The following is the East group of Tv stations.
The East group of Digital Tv stations/channels are Very Weak of signal strength.
KTAL-DT REAL UHF channel 15 , virtual number (6.1) NBC.
KTBS-DT REAL UHF channel 28 , virtual number (3.1-2-3) ABC and Local Weather and News.
KSLA-DT REAL UHF channel 17 , virtual number (12.1-2-3) CBS and This Tv and Bounce.
KMSS-DT REAL UHF channel 34 , virtual number (33.1) Fox.
KPJX-DT REAL UHF channel 21 , virtual number (21.1-2) CW and Me-Tv.
KSHV-DT REAL UHF channel 44 , virtual number (45.1) MyNetwork.
KLTS-TV REAL UHF channel 24 , virtual number (24.1-2-3) PBS.
Antenna system number 1.
The East group of Digital Tv stations/channels has PBS , the South group does not.
I recommend reception of the East group. To start with.
Install a Antennas Direct DB4e antenna with a Antennas Direct CPA-19 preamp aimed at about 105 degree magnetic compass direction.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , some times named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Antenna system number 2.
For reception of the South group of Digital Tv stations/channels.
Above the roof install a Winegard HD7698P antenna with a Antennas Direct preamp aimed at about , 180 degree magnetic compass direction.
Antenna systems 1 and 2 are SEPARATE antenna systems and Are Not connected on to one coax.
The 2 Separate systems are separate All the way to Tv/s locations where the separate system coaxes are connected to a Remote control A/B antenna switch at each Tv location.
http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
Remote control A/B antenna switching is , Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
So y'all are recommending a Winegard HD 7698P over the Channel Master 2020 ? Why ? It's only rated 10 more miles (70) than the Channel Master 2020 , which is far less (Around 40 dollars at some places).
Also, the VIP 722 scans the locals for us. I would be interested in picking up only one set (Seeing as they are all affiliations and would carry everything the same besides local news). However, KLTV is where we watch the news at. Other than that, I don't care which set of locals. I think KLTV would come in fine if I pointed the antenna towards the Shrevport (East) locals, assuming that the Winegard or Channel Master is like the RCA one I still picked up KLTV pointing towards the East at about 85 signal strength, and usually 100% towards the south.
Name141 is offline   Reply With Quote
