Old 27-Sep-2012, 5:41 AM   #5
It is best to install antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
I see that the bottom antenna is aimed directly into the Thick part of the tree.
Is the top antenna also aimed in to the thickest part of trees??
Are the 2 antennas connected together on to one coax??
The 2 antennas can not be connected together on to one coax.
