Any loss between the antenna and preamp is loss that the preamp can not overcome. The preamp belongs close to the antenna. The power supply for the preamp needs to be protected from the elements and there should not be any splitters between the power supply and the preamp (unless the splitter is designed to pass power).
While you're installing the preamp correctly, give the antenna a thorough inspection and consider trying a new balun.
