Old 26-Sep-2012, 8:19 PM   #22
slowboy
I mounted the preamp right where the cable goes in the house. I would say 60ft down from the antenna. You know you may be right on the cable now I think about it. I was undoing a splitter in the attic and the cable was RG6 I believe and outside the cable is RG59. I need to go back and verify. I have though tried running the cable through the window with not much improvement before but not with the amp installed.
slowboy is offline   Reply With Quote
