Old 26-Sep-2012, 3:19 AM   #14
No static at all
No static at all's Avatar
I'm thinking it's more of a signal quality issue at this point. The VHF section of the Channel Master antenna is just not that good when it comes to rejecting multipath. The specs indicate a rather wide VHF beam width which is not good unless a clean, reflection free signal is seen at the antenna. There is no reason why you shouldn't be getting the desired VHF channels with one set connected directly to a proper antenna.
If I were in your shoes, I would also consider the Antennacraft HBU 33 from Radio Shack as a possible solution. If it doesn't help, you can always return it for a full refund.
