Old 25-Sep-2012, 4:51 PM   #6
If you look at the tvfool channels list you will see the word - Azimuth - and you will see the words , True and (Magn) with numbers under them.
And at the tvfool radar plot you will see the group of Tv stations at 220 degree magnetic compass direction.
And you will see that those Tv stations/channels are the the ones to receive because those Tv stations are the strongest to receive in the yellow reception zone. And they are the ones that are , NBC , CBS , ABC , PBS , Fox , and etc. .
Yes the HDTVa at Crutch Field is a HDTVa antenna.
Yes you can try Tv reception Inside the apartment.
You can try the HDTVa in the east facing window , and it is Ok to receive Tv reception in other windows that are to the , west , south west and south , because that is where the Tv stations are at.
If required a long coax can go from the HDTVa antenna to the Tv.
Rescan for the digital broadcast Tv channels when the Tv antenna location or direction changed.
__________________________________
Question. Are there any of those small dish network or direct tv dishes on the outside of the apartments??
If so , then here is Broadcast Tv Antenna that looks like a small satellite dish , on purpose. http://www.antennacraft.net , HDX1000.
