Old 25-Sep-2012, 2:21 PM   #5
ILoveCoffee
Originally Posted by teleview
If the apartment building is . wood with wood or vinyl siding , no metal roof , and no metal backed insulation then install a TERK HDTVa antenna aimed at about 220 degree magnetic compass direction.
Here is how to aim indoor type antennas.
The follow is a incomplete list of building construction that will reduce or block broadcast tv reception.
If the building is , concrete , concrete block , concrete roof tiles , bricks from ground to roof , big rocks for walls , metal siding , metal roof , metal backed insulation , solar panels .
Better reception will happen with the antenna in a south west facing window.
Is there a patio to the , west , south west , south??
As always , trees and tree leaves will reduce or block Tv reception and so do buildings and other obstructions.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
Thanks a ton with this help. The open side is East only. All other sides are covered by another apartment blocks or thick trees. Unfortunately, there are bricks from ground upto the roof.
Are you talking about http://www.crutchfield.com/p_209HDTV...a.html?tp=3261 ?
Do you think, its even worth a try?
Just curious, how did you come to the conclusion 220 degrees. Can you derive that from radar data? (Apologies if any questions here are stupid)
ILoveCoffee is offline   Reply With Quote
