Thread: Outdoor Antenna
Old 24-Sep-2012, 6:56 PM   #20
You tested the antenna in the attic and picked up all the channels in the list.
With the antenna above the roof with the antenna mounted in such a manner that the roof is not in the way of reception , You were saying that ABC is a little weak , NBC is weak also??
Now that I see how the house is wired with coax.
A better amplifier setup is a Antennas Direct CPA-19 preamp.
http://www.solidsignal.com , http://www.amazon.com.
