Old 24-Sep-2012, 5:52 PM   #1
jpursell
Signal Loss Suggestions
Having some signal loss issues and need some advice.
This is my report:
http://www.tvfool.com/?option=com_wr...2df94baa072f42
Summary: I’ve compromised on the antenna direction to try an pick up the most channels I could. We primarily watch(ed) channel 13.1, and since that was the furthest away, I pointed the antenna in that direction ~330°. I still have issues occasional issues with almost all the channels I’m receiving with the picture freezing, dropping out, and then coming back on. I’m assuming that antenna’s direction is causing the issues with the channels other than 13.1.
1) Would a Pre-Amp would help, or do I just need to give up on channel 13.1 and settle for the channels from the south?
2) Should I have purchased a different antenna?
3) Would a rotor help with being able to receive 13.1?
Antenna:
I purchased and installed this antenna 2 months ago: Winegard HD7694P High Definition VHF/UHF Antenna
Install Details:
I mounted the antenna on my roof (2-story house) to an existing J-bracket mounted about 1/3 of the way down from the peak. The J-bracket was previously used for a Dish Network dish. Used the same existing wiring which was installed for the dish, which goes from antenna to a combiner, and then a homerun to the main TV. There is a ground wire running from the combiner to the main ground pole for the house.
Primary channels we watch:
ABC – prefer channel 13.1 over channel 41.1
Fox – 17.1
NBC – 8.1
CBS – 3.1
Thanks in advance!
Jason
jpursell is offline   Reply With Quote
