Thread: Outdoor Antenna
Old 24-Sep-2012, 2:23 AM   #17
trek_fool
I ran the coax yesterday (2 drip loops, one below antenna and the other at the base of the mast) and found the best alignment of the antenna at 90deg (magn). WAFF (NBC) is the only station at 99deg. and comes in fine. WAAY (ABC) has a weak signal and I was not able to improve it at either direction.
Should I elevate the coax running between the downspout (photo 2) and cable box (photo 3)?
The coax is grounded at the box with a grounding block.
trek_fool is offline   Reply With Quote
