The following is a Teleview recommendation for brodcast Tv reception.
WIBW-Tv VHF channel 13 , is 20.9 NM(dB)
KAAS-DT UHF channel 17 , is 18.5 NM (dB)
KTWU UHF channel 47 , is 14.3 NM(dB)
K36IO-D UHF channel 36 , is 4.6 NM (dB)
and then the next tv stations go into the negative numbers.
And the evaluation is that those Very Weak NM (dB) numbers are too strong for a CM7777 preamp.
No way those Weak Tv transmissions will overload a CM7777 preamp.
________________________________
And a Grain elevator 1/4 mile away , will not , reduce or block signal if it is in the direction of reception ?????
_________________________________
danthesoldier , what direction is the grain elevator from your house??
Is the elevator the Big concrete type , or the smaller metal type??
