I assume that your antenna is UHF. If so OK you will only lose Fox 8. If your antennas are UHF/VHF your antenna may not be strong enough. I would go to an Antennas Direct CS2 complete UHF/VHF combo.
Just do the following and your reception will be great:
Remove one of the antennas and install an Eagel Aspen Roto100 rotor.
Install a Winegard AP8700 amplifier. This combination will allow you to use the rotor to operate thru the existing coax, provided you follow the manufacture instructions for single coax installation.
Some would say that rotors are not surfing friendly and I somewhat agree, but this simple system will deliver many channels with the least equipment, expense, and frustration.
Reason: Deleting off-topic content
