Old 22-Sep-2012, 1:58 PM   #3
If the apartment building is . wood with wood or vinyl siding , no metal roof , and no metal backed insulation then install a TERK HDTVa antenna aimed at about 220 degree magnetic compass direction.
Here is how to aim indoor type antennas.
The follow is a incomplete list of building construction that will reduce or block broadcast tv reception.
If the building is , concrete , concrete block , concrete roof tiles , bricks from ground to roof , big rocks for walls , metal siding , metal roof , metal backed insulation , solar panels .
Better reception will happen with the antenna in a south west facing window.
Is there a patio to the , west , south west , south??
As always , trees and tree leaves will reduce or block Tv reception and so do buildings and other obstructions.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
